I'm trying to install the IBA under the manifold so my butterfly can open. Does anyone know where i tap the wire at on the ECU...
IBA (butterfly) Installing help
I dont think there is a wire for the ecu isnt it just a vaccum line that u have to hook up
GOT BOOST???
massive part out on accord almost everything is going
http://www.cb7tuner.com/vbb/showthread.php?t=125294
well i gues your only aanswer is to use your search engines. i will check for you though.
GOT BOOST???
i have searched and got no results i am not exactly sure what u are trying to do also.
GOT BOOST???
^seconded
http://www.cb7tuner.com/vbb/showpost...8&postcount=17
It is recommended to run the wire into the ecu and solder it down. The way I did it originally would just shake loose and come undone after a short time.
FYI its IAB. If you typed in IBA your not gonna find anything in the search. But just wire it directly to the ECU you should be fine. Dont need to solder it down as long as you put it in right. The only places I would recommend solderings are places that are spliced and such.
