IBA (butterfly) Installing help
    I'm trying to install the IBA under the manifold so my butterfly can open. Does anyone know where i tap the wire at on the ECU...
    I dont think there is a wire for the ecu isnt it just a vaccum line that u have to hook up
    GOT BOOST???
    massive part out on accord almost everything is going
    http://www.cb7tuner.com/vbb/showthread.php?t=125294
      naw there a plug also
        well i gues your only aanswer is to use your search engines. i will check for you though.
        GOT BOOST???
          i have searched and got no results i am not exactly sure what u are trying to do also.
          GOT BOOST???
            Pin A17 of the ECU.
            ...adjust accordingly
              ^seconded
              http://www.cb7tuner.com/vbb/showpost...8&postcount=17
              It is recommended to run the wire into the ecu and solder it down. The way I did it originally would just shake loose and come undone after a short time.
                FYI its IAB. If you typed in IBA your not gonna find anything in the search. But just wire it directly to the ECU you should be fine. Dont need to solder it down as long as you put it in right. The only places I would recommend solderings are places that are spliced and such.
                  use your head silly
                    accordaffair I was reading the post you linked to. it does not mention swaping ECU's?
                    '90 Accord LX, 5spd.
                      You need a Pt6 ecu to run the IAB's
                      Otherwise, you can use a vacuum line straight to the IM plenum, but it isn't perfect.
