Originally posted by cp[mike]
1990 to 1993 Accord engine?
Alright, another small block Chevrolet guy! We're pretty much kinda like a cult here in the Honda world. Anyway...
To answer your question about the cam...obviously the motor was starved of oil. Either it no oil in it to begin with, the oil was too slugged up to circulate properlly, or the balance shaft oil seal popped out. Whatever the case may be, the engine is wasted. And yes, these are interference engines. If the timing belt or the cam itself breaks, you can bet you'll have some bent valves on your hands.
Best thing to do is swap in a new motor. Like everyone else has already stated, any F22A, F22B, H22A, or H23A engine will fit. But the easiest swap will be to throw in another F22A6.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
i would luv an H22 motor, but i gotta say that a turbo F22a motor would be fun to play with...but u better build that block first before slapping any turbo on it...or u could just slap on that turbo and just hope and pray that u dont blow that motor....
turbo'ing an unbuilt motor is like gambling...1st u set the turbo about 6psi, cuz its a new experience and ur scared...so u bet small...it works and all, therefore, u get alil confident and cocky...2nd u set the turbo about 8psi, cuz u think, "hey its just two extra lbs."....that may work(which wont last long) or may not work, depending on the condition of ur motor b4 u slapped that turbo on...but lets say that it does work and ur happy about the extra horsepower...but then...u get greedy(ie. gambling)...u see kats out there pushin' like 10-15lbs. easy...and u only pushin' like lil ol' 8lbs...3rd and finally ur dumbass sets that turbo about 10-12lbs....then u take a lil test run...oh and u push that btch...about third gear to the redline, u hear a bigass pop...and all u hear is, "puut puut puut""KNOCK! KNOCK! KNOCK!""GRIND! GRIND! GRIND!"!!!...by now...u know u blew ur motor...then somehow u make it back to ur driveway and ur sitting in ur car thinking wat ur gonna do...by this time ur engine should of grew legs and arms...jumped out of the engine bay...opened up ur door and sat in the passager seat...then two seconds later...GIVE U A LEFT HOOK FOR TURBO'ING THAT HIGH(on an unbuilt motor)...A wise man sees failure as progress...
Originally posted by dgouldThanks to all that have spent the time and replied. I just need to make up my mind and decide which direction I want to go. Sounds like getting a hold of a Prelude my be the way to go. I would lust need to a 1990-1999 Prelude right?
Thanks again, you guys rockA wise man sees failure as progress...
Originally posted by trcsbrianIf you drive an EX then your stock motor is definitely an F22a6. I'm pretty sure the f22a6 has 140hp. I think every single engine listed are the engines that fit with barely any work. But just incase, I'll give you a quick run-down of the most common engines used. F22A, F22B, H22, and H23. I think thats it.
F series:
F22A Stock (A1/A4/A6)
F22B SOHC (94-97)
F22B SOHC VTEC
F22B DOHC ( JDM )
F22Z SOHC VTEC ( EDM )
F20A SOHC ( replacement )
F20A DOHC ( JDM )
F20B DOHC VTEC
F23A SOHC VTEC
H Series:
H22A
H23A DOHC NON VTEC
H23A DOHC VTEC ( Rare )
Please be MORE specific with him!
the swappage is endless!
and if you have alot of money and TIME...
you could shoot for the
K series: ( alot of fabrications ) $$$
K20
K24
or the J series: ( alot of fabrications ) $$$
J30
J32
the possibilities are ENDLESS...money, skill , and time talks!
NOTE: you can also do frankensteins
F22 series block with any H series head!
H23 block with a H22 head!
you just have to SEARCH! like many has already stated....SEARCH!
we will help you with some things..but you will HAVE TO..do research on your own!
SEARCH....SEARCH...SEARCH!
and Welcome aboard!Last edited by SN2BH22CB7; 04-08-2007, 07:25 PM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Originally posted by jyoungblood87i would luv an H22 motor, but i gotta say that a turbo F22a motor would be fun to play with...but u better build that block first before slapping any turbo on it...or u could just slap on that turbo and just hope and pray that u dont blow that motor....
MR Thread:
