Building the bottom end for turbo
    Originally posted by teknikalitch
    so what im getting out of this thread is this...
    buy forged pistons for my current block
    new main bearings...
    headwork...
    if the crankshaft and rods are already forged then can i use the rods in it now with new pistons? those bastards are expensive! getting 250+ HP would be my goal would that do it @ x amount of boost? say 10 if its 10hp per 1lb boost.
    10psi 14b turbo is around 250hp tuned
    miss my turbo cb7
      who do u guys recommend for main bearings???
      A wise man sees failure as progress...
        OEM or ACL.
          BUMP
            D112 just told you.
              BUMP
              they are the first things to blow.
              miss my turbo cb7
                u gettin new rod bearings i assume right?
                http://www.get-gifts-for-free.com/?ref_id=4810
                1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
                  on what? Rings will go out before anything.
                    i dont stand by that. 92ex blew his bearings, and his rings are fine.
                    miss my turbo cb7
                      so u guy are saying that the rings and bearing are usually suspect to blow first??? im putting new oem pistons w/rings and forged rods with new acl bearings in... any suggestions...
                        ok... being new at this im going to ask a silly question...
                        here goes.
                        if a 14b turbo will push around 250hp at 10psi
                        what is the difference in a t3/t4 turbo at 10psi
                        ive been thinking it over and have decided to go with forged pistons, arp headbolts, and headwork done at a local shop. the turbo kit im looking at is t3/t4.
                        R.I.P.
                          here goes.
                          they are bacically the same. i think the t3 might be slightly bigger. just the dsm 14b bolts up to the f22a with some drilling on the exhaust mani.
                          miss my turbo cb7
                            yea thats what we bacically are saying. the piston rings blow from the psi in the cylinder, and the bearings blow from the psi applied to them.
                            miss my turbo cb7
                              You need to stop giving anyone advice. 90% of things you say are wrong.
                              You cannot just say t3/t4 because there are a lot of variations of that turbo!
                              There are some that are just as small as a 14b and some bigger than your chest.
                                dude you need to chill the fuck out, cus your really pissing me off. i tell people what i know, no time for research. thats what people should do when they want something.
                                ok, now thats sick.
                                miss my turbo cb7
