I have a noise when my manual trans is in gear even when clutch is depressed. New trans and boots but still have small leak and noise is louder when driving. Any ideas?
noise front left
doesnt sound tranny related. could be small, like some random bolt rattled loose and it only makes noise when its in gear and shaking a little more. or 2 things rubbing together because of the car shaking in gear. ive found things like this to be the problem many times.
is this only when you are moving?
give us a little bit more details and maybe we can help u more.
if noise gets louder when driving then maybe belts, possibly axlesProject M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-
Does it make this noise when you're not moving? Or if you are moving and press the clutch? And if you are driving with the clutch depressed does it still do it? Under accel or decel?R.I.P. CB7; hello spec-v!
Member's Ride
FS thread: full part-out
Help me with my spec-V fund, buy my stuff!!!
Degree of rice and performability are inversely related.
Yep let us know what it sounds like sound wise. Probably one of the hardest things to diagnose on the web but you can guess about where its at with a description of a sound. Also your sig is too big.
Sorry about the sig. It makes a clicking noise on passenger side. Louder when in gear even when clutch is depressed and sitting still. Out of gear and clutch depressed no noise while sitting still. Driving noise in accel and decel but when clutch is to the floor and car is coasting out of gear I don't hear it very much at all. Does this help? I hope its not the tranny, it was just put one in 2 months ago. Thanks for any input!
Got with a friend and lifted it to get a full view on Easter Sunday and its the tranny. Anyone know of a GOOD place to order rebuilt/reconditioned trannys (f22a4 engine)! Obviously where I bought mine sux! Its my fault; I bought it with a lot of other parts at the same time and by the time I put it in the warranty had already ran out! Thanks for all the info guys!
