well i've heard u cant just remove the hoses and plug them cause somthing will seez up. So can anyone help me on how to properly remove my power steering if theres a thread on this lemme get it or if u can take pictures and explain it to me it would be really nice thanks.
How to remove Power Steering??
well what i did was...i took out the power sterring pump and braket....left the resevior with fluid in the...and for the hosing....i just put electircal tape around it...6 months later...i decided to check if my power steering still works...and yes it does....and nothing seezed up on me...well...hope it helps..Signature removed due to excessive size. Please read the rules before creating a new signature. - cp[mike]
OR ghetto loop it which is the easiest way. Get a hose clamp and loop both hoses on the pump together. Works too and you can take out the pump after that.
I removed my power steering pump hoses and reservoir but I looped the rack and made a small power steering fluid reservoir using a spare clutch fluid reservoir and cutting the clutch tank bracket and bending it around ran a line from the tank to a t fitting the looped that into the rack, I also filled and looped the vss/ but turning isn't too bad and the rack is always full of fluid and it looks stock.
