my brake lights wont come on when i step on my brakes all the bulbs are fine...the tail lights light up when i turn my headlights on but it doesnt get brighter when i step on my brakes like they should...any suggestions?
HELP::brake light question
Originally posted by N9netwoAccordcheck the fuses
if not , check your brake light switch under the brake pedal.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
brake lights FUBAR?
Hey, is your car an automatic?
If it is, when you step on the brake pedal--if the brake switch is working--you should hear the solenoid that engages to allow you to shift from Park. If you do not hear that click then that just might confirm your brake switch (which is located at the brake pedal ARM) is likely POO POO. Or maybe a wire came loose.
GOOD LUCK EHYEP. I AM Canadian.
1990 Accord EX 220,000 KM. Essentially stock with 15" alloys and chin spoiler added. K&N filter and Bosch plugs. ICE COLD A/C which I love!
1992 white EX 4 dr, 5 spd. (602,000 Kms and I JUST RETIRED IT. SO SAD!) DEC 9TH, 2005 - MAY 31, 2012. I added 229,000 kms to it. Great car!
mine did the same thing it was a fuse but i heard of some people having the same prob and it being a relay93 accord: F22A swap,T3/T4 turbo, tail wastegate, front mount 27x13x3, hks turbo timer, turbo xs boost controller, msd igintion, 3in downpipe, crane cam 11mm plug wires, denso plugs, no ac or ps,wire tuck, cutted insides, one seat, auto meter boost gauge,oil pressure, a/f,and 5 in tach,act clutch and flywheel.
93 prelude: jdm headlights,OEM carbon fiber hood, tein lowering springs, work racing rims with kumho tires, msd wires and denso plugs,type r shift boot
