h23/h22 turbo project
    Hi all, I'm new here, names Tony and I'm brand new to the honda world.
    I've actually been working on this project for a few months and I'm starting to hear some negative things about the engine setup I've chosen for my first project.
    I've taken an H23 block and slapped on an H22 head (longer stroke with DOHC Vtec) and added a t3/t4 turbo to it.
    The engine is complete now....with turbo....sitting in my buddies garage, but I want to hear some oppinions on the durability before I go out and start breaking her in.
    Will this block stand up to the torture of 6 lbs of boost?
    Well first things first......What did you do to the internals?!
    ^Click to view my Members Ride Thread^
      it can take a good beating.
      Just make sure it's fully tuned and dont go crazy on the timing.
      You also might want to consider a high volume oil pump. Frankenstein engines die due to 2 things:
      1. not enough oil pressure
      2. and too much timing
      h23 blocks can take a good amount of boost, as long as it tuned.
        We used an H22 oil pump....and let me tell you what a joy that was to find!!!!!!!!!!!!!!!!!!!!!!!!!!
        They were on backorder for a few months, finally found one site that had it....as well as the engine mount brackets I needed. So if anyone is having a heck of a hard time finding a part that you need, try out majestichonda.com
        And to answer the question asked, I pretty much left the internals stock, we did do a rebuild which included all gaskets, all rings, and a few trips to the machine shop.......and the most extensive-pain in the behind-head cleaning ive ever even heard of.
        which brings me to my next question.......will stock engine mounts hold up to that same torture? Maybe if we pour them with poly?
          def fill them with poly.
            H22s and h23s are pretty strong engines and being rebuilt will definately help and make it last longer. 6 lbs of boost def shouldn't be too much. As for the mounts, since you have the engine out anyway you might as well get some new ones. Couldn't hurt.
            R.I.P. CB7; hello spec-v!
            Member's Ride
            FS thread: full part-out
            Help me with my spec-V fund, buy my stuff!!!
            Degree of rice and performability are inversely related.
              well i have the stock left and right mounts, but I have to buy the front and rear anyway, so I'm kind of looking for suggestions. Should I just go with stock and pour them or should I get some aftermarkets?
                i would poly fill them. it is alot cheaper! lol
                1993 Honda Prelude H23t -big 16g turbo, uberdata, and a kick ass body and paint to go with it!
                  6lbs should be safe. Frankenstein motors aren't always reliable, though. It sounds as if you did it right, but still be prepared for failure. I've seen more failed franks than I have successful ones.
                    I guess I could tell you all a little more about the car.......
                    It will be a sleeper of sorts, the intercooler is almost completely hidden by a bumper cover chop job.
                    Right now it is lowered 1 inch on adjustable coilovers, could go down 2 or up 4 from where im at.
                    bought 17" gun metal-chromes, not sure on brand but i really like them (got them for 175 with 2 good Kumho tires)
                    Altezza chrome tail lights, Chrome projector headlights
                    Its champaigne-with burgandy int.....ugh......I'm thinking gun metal with black cherry tinted clear for paint....might do black or grey int swap
                    grey on black racing seat covers all the way around right now
                    A pod (i think.....the one that attaches to the left of the windshield) with blacked out LED boost guage and oil pres guage (i really like my guages)
                    went with continental contisport Z rated tires, descent tire for pretty cheap
                    Got the quietest BOV I could find, dont know brand but I dont want it heard much
                    High flow cat, were going to put a Y in the exhaust to bypass it anyway though
                    plan on getting high flow intake but as cheap as they are I figured that could wait till last
                    anyway, i was thinking about doing some sort of Lip kit....if they make them for the CB7's, i know they do for the 92-95 civics.....
                    well, let me know what you think of my project.........
                      nice im gonna do that swap too turbo as well lemme know how that turns out man..i ordered my lip from jdmcarboy but i think they just got me for my money cuz i heard another guy in here who has the same problem...so now that they got it on ebay imma order it...but if u find the lip kit please lemme know asap...thanx man...
                        so heres a silly question that I have been pondering since I started this project.......with the frank and 6lbs......any clue what HP/torque I should expect with a good tune? based off of stock specs on h22/h23.......im kind of expecting about 200 hp and about 160 torque unboosted........just my personal guess???????
                        another thing I have to ask.......how well do the CB7's hook up from a dig (with the frank-boosted)? My mechanic is kind of hinting that I may have to really back off of the pedal in 1st and 2nd to avoid a john force burnout. Any thoughts would be much appreciated.....
                          6 lbs of boost is deffinetly not a lot on these blocks they are tough blocks just be aware of getting enough oil and watching the motor.
                          GOT BOOST???
                          massive part out on accord almost everything is going
                          http://www.cb7tuner.com/vbb/showthread.php?t=125294
                            a good estamite of power would probly be around 190-220hp the h23 is a good block and the h22 head is even better for turboing.
                            also the cb7s hook up good as long as u dont rev the hell out of it and drop the clutch.
                            GOT BOOST???
                              well, 190-220 unboosted.......but what about with boost?
