Problem
    Problem
    heres the situation i was driving to work and when i hit da gas to accelerate from behind a slow moving car, the car accelerated for a few feet then accleration stoped but it rev'ed like it was in neutral. i pulled over and the belt was half off so i put it on and re-tightend it. when i went to go start the car it wont turn over. but i can hear the starter but nothing is turning........
    i think it might be da starter but im not sure......
    any sugestions??????
    SPYDER CB7S
    ONE CLEAN CB
    ummm what??? let in some more details.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      snapped timing belt?
      clutch gone out on you?
      need more details.
        when the car accelerated it felt like somthing let go and the engine rev'd like it was in neutural.......
        so when i tried to restart the ,car after puting the belt back on, the starter sounds like its turning but thats all that happens... nothing else turns.........
        it has gas,power,all fuses are fine,belts are ok,......
        SPYDER CB7S
        ONE CLEAN CB
          which belt fell off?
          have u taken off ur valve cover and looked at ur timing belt? see some of the above suggested problems.
          F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
          Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
          Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
            the belt connected to the power steering.....
            SPYDER CB7S
            ONE CLEAN CB
              That belt has nothing to do with acceleration. I cut my belt off
              If you have a manual transmission, it sounds like your clutch is shot. Automatic... I dunno... something is shot
                if you cant start it then its not the trans. My auto went out and was slipping like crazy and i could still start it fine. check your main relay, ignitor, distributor, cap rotor, basically look over the ignition system. mine went out in november and the starter was turning over but it wouldn't create spark. its likely this
                  If it won't start, check the battery, igniter, coil, and main relay. If it just whirs, the starter is done.
                    i got it fixed...the problem was the timing belt broke and the fly wheel was gone...
                    SPYDER CB7S
                    ONE CLEAN CB
                      woah, your timing belt broke? i hope you replaced the water pump also.
                        Damn dude I know that had to suck...... Did you find the issue or did someone show up to help you out?
                        My Members Ride Thread ( Do It )
