I have a 92 accord LX. Almost like my car has a mind of its own. Sometimes when I come to a red light the car will bounce its idle almost stalling out and then returning to normal over and over, and then other times the idle is fine. Also the beep sound when you turn the car on comes and goes as it wants to. My dome light doesn't turn on when the door is open, and it doesn't register on the gauge display that my door is open. What is it? Main relay? Fuses? HELP!
Idle Problems and much more
Okay with the stalling.... turn ur idle screw.. located on the throttle body.
The dome light... the light might be busted. pry of the lens with a flat head screwdriver or butter knife and check the bulb, if not that, check ur fuses.
Seatbelts, the seatbelt sound is what ur hearing and it comes on when the seat belts aren't on. It comes on occasionally as u travel reminding u that u or your passenger(front) doesnt have their seatbelt on.
Light on dash.. check your fuses, have u taken off ur dash any? to install guages, etc?Member's Ride Thread
Originally posted by deevergoteDon't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
