I just changed the ac condensor motor, and i got a new compressor but my ac does not work. When i turn it on from the inside there is no air coming out of the vents. What should I replace or what needs to get fixed?
Ac
Did you charge the system?
First off, make sure you have the fan on. If no air comes from the vents, then that's a problem with the switch, the resistors, or the motor. Try setting the fan to its highest, if it works then its most likely the resistors that allow the slower fan speeds.
As for the A/C, double check the A/C pressure switch is hooked up. Then turn on the fan and turn on the A/C, and check that both engine fans and the compressor pulley are turning.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
