automatic trans sticking
    i toke my car out today to see if the white smoke that was coming from it stop and yes it did but when i went to park the shifter got stocked between park neutral or what ever below it i had to rock it back and forth to get it to unstuck and back in to drive what can be the problem i been fixing this car for a while i know it need brakes there shot but why is the Tran getting stock
    4 door ex-l
    My guess would be brake sensor. let the brake out all the way and push it down all the way several times and see if that will free up the transmission. You can always use your key in the transmission lock on the shifter console. The few times ive seen a cb7 tranny get stuck it was realy cold and the (relay i guess) was froze or too cold to enguage.
    If its mechanicaly stuck you could be much worst off. Somone else on here that knows the interal mechanics of the auto trans could help you better.
    I cant Slam further. The ground refuses to get any lower.
      If it's the actual shifter that's stuck, it could just be the shifter cable. I know my shifter cable got jammed or something (don't know the exact details) and my shifter would only move a bit, between N and D4, so my tranny was always in drive. Had to push the car out, start it in N, and then go to D4 and drive. Hope that helps. GL.
