Accord suspension- any weakspots
    im starting to get worried about my 91 EX sedans suspension. it seems to ride fine, but the turning feels kind of wobbly and everytime the car goes over a bump i get a clicking or a hard noise. are there anythings i should look for. i dont really want to pour any money into this car if the suspension is that messed up because i already have to service the coolant system, brakes, tires, and transmission.
    You may just have crappy front sway bar bushings. I'd get it up on a lift and take a look.
      Check for worn swaybar link bushings. My car had loud clunking noise when going over bumps and turned out to be swaybar bushings are worn. While you're at it check for worn balljoints (lower and upper).
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        I found out that my swaybar bushings were shot when I heard a thunking kind of sound when I went over speed bumps...but i got it covered for about $200 CDN at a honda dealership if i remember correctly.
        Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
        Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
          yea bushings are pretty cheap, i just hope its nothing serious like i need to replace the whole struts/shocks
          its definately not wheel bearings or axles though, the wheels make no noise when rotating, just a little thud noise when hitting a bump
            believe only bushings... coz if your struts are bad , you'll be bouncing. axels are clicking on turns. bearings are humming noises. so bushings are your culprits.
              Yea I had the same problem with my Accord. It clicked when it turned and i wasn't sure what it was. I changed the Balljoints, the Axles, and the bushings. I still have a humming noise when i turn, so I'm guessing those are the bearings. Thanks for the info. I came on this threat to help and I learned something about my car
