Maintenance Required
    well the so called "Idiot light" came on....
    I lost my manual...
    What does it mean?
    No longer have a cb7.
    V6 POOOWAAAA
    lol, a buick.
    The lil red indicator or check engine light? I dont remember a maintenance required light?
      it means "GET ON YOUR SHIT " J/K
      when is the last time you did a tune-up on your car (oil change,spark plug wires,air filter if you still use that,even rotate them tires)?
        x2.....well the red indicator is a reminder and the check engine light means there's something wrong
        Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
        -(B-Pillar Bar Originator)-
          An oil change was January 21st.
          Spark plug wires? I haven't done anything since I've got the car in october, am I supposed to?
          I have an intake.
          I haven't rotated tires since I"ve got the car or done a transmission fluid change.
          The little indicator underneath the tach instead of green, its orange.
          V6 POOOWAAAA
          lol, a buick.
            it turns every like 7500 miles or so i think. its just a reminder and its not hooked up to anything mechanical wise.
            and 407accord huh? any relation to 507accord?
              What turns? The color?
              No? my name is my area code oc, fl and accord, I am the 407 accord. hahaha
              V6 POOOWAAAA
              lol, a buick.
                haha nice
                it turns to orange then red after a while. just stick ur key in the little slot there to reset it.
                  I have an intake.
                  if would be smart to change the spark plugs and the cable just to be safe,check your tires, brake pads, and all your oils level,take a run around the block with the car and pay close attention to her heart beating .
                  if there's anything wrong with her you should feel it.
                  last reset that shit to green
                    I just got brand new brakes.
                    Could possibly be spark plugs
                    Why does it change colors? Once it gets to red does that mean something definately needs to be changed?
                    Thanks guys.
                    I have bent tire and my car shakes when i drive could thatb e it?
                    V6 POOOWAAAA
                    lol, a buick.
                      its there just to serve as a reminder to check your shit out, lol. it doesnt indicate a problem, only gets your attention. it changes about every 5k miles. just check everything, maybe get a tune up (ie. plugs, wires, filters, oil...) just to be safe.
                        I know of the lil indicator on the tach. But a light I am not sure since he said light so thought maybe check engine.
                          Thanks guys.
                          just like 93accordexcoupe said "it turns every like 7500 miles or so i think"
                          it's like a timer or a reminder,don't matter if your car is running good or not the shit will always change,just make sure that you keep up with your maintenance,or the shit will pile up and then you'll be fuck.
                          so whatever is wrong with her just get them fix.
                            ah I see. ok thank you
                            and lawdo ok those are called clear bumper lights right?
                            what do they serve as?
                            V6 POOOWAAAA
                            lol, a buick.
                              Where you put the key to reset that light? Cause Mine is also REd. After my motor swap was done and drove like 500 miles to break in my stage 3 clutch.
                              1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
