91 Exhaust
    91 Exhaust
    I need to find a picture of a full exhaust from the headers to the muffler for a 91 accord 2-Door.
    Thanks,
    Pete
    Why a picture? Ebay? They usually have picturs of a full system.
      Yeah i got a picture. I needed to know where the cat was located exactly on the exhaust. Apparently the accord I just bought does not have a cat which i need for an e-check
        Between the downpipe and where the rest of the exhaust piping goes. Or basically after the downpipe.
          Why wouldnt you have a cat, who sells you a car without a cat and dosnt tell you it dosnt have a cat.. ebay sells cheap ass cats for $30, they work and should pass a emissions test if everything else in your car is in good working condition.
          From the engine... header/ downpipe and flex pipe / cat / resonator / tail pipe / muffler
          (every where there is a "/" there is a break in the pipe where the previous part bolts to the next)
          header: bolts directly to the engine
          Downpipe: bolts to the header, goes from the header to under the engine. Includes a flex pipe (looks like braded metal)
          Cat: bolted on right after the flex pipe
          Resonator: Bolted to the cat first part is shaped like the cat and can run all the way to about where the rear tire is.
          Tailpipe: Bolted to the resonator. Can include a muffler welded on.
          Muffler: either bolted or welded onto the tailpipe
          This image has been edited, and represents my own artistic work. Ill take it down if needed.
          I cant Slam further. The ground refuses to get any lower.
            That is not a cat in that picture. It is a mini resonator. If you want a cheap cat get a carsound off ebaythey are like 60 or so shipped. Those lil resonators wont let you pass smog. They act like a test pipe which is mostly illegal wherever emissions testing is.
              It depends on the dealer, some are test pipes some are cats. Look for a dot approved or iso9006 aproved cat. Should have a sticker on the cat if im not mistaken.
                Well the previous owner did not tell me that he replaced the cat with a straight pipe which he did a horribe job welding so it leaks. Although I cannot complain I did get a good deal on the car. Theres a cheap shop around by me that does cats for cheap I guess so I'm just gonna go through them. Thanks though guys.
                Pete
