Ok, well I've decided to keep the accord rather than go with the civic. I got all the basics, I/H/E, high voltage coil, platinum plugs(NGK), plugs wires, cap, rotor, clutch, flywheel, 10w-30 royal purple, coilovers, strut bar. So I was thinking, what is something else basic that I can do next to get some more power?, something relatively cheap and easy. No turbo or motor swaps, just something that will beef up the f22a1 a little more without killing the mpgs'. I'm not a super mechanic(soon to be hopefully) but I was thinking in the means of maybe a bigger camshaft or cam gears? Can't seem to find a beefed up camshaft for the f22a1, any links? But if any of you guys have any other ideas on what I could do that isn't too hard or overly expensive, I would really appreciate it. Thanks alot for the help.
Keeping the accord/need some mod ideas
Check out F22parts.com for cams, but if you are not comfortable with timing belt changes, I would stay away from that as a DYI. Cam gears are not going to give a lot of bang for the buck. You would spend a lot of time on the dyno to actually see any gains from them as you would have to make a pull, then alter the gear setting, then make a run and so on and so on. 1 degree of change in the gear can mak the car run better or run worse, and each motor is a little different when it comes down to it. What would work for cam timing on one members f22a1 setup more than likely may not be what your f22a1 setup likes to see for cam timing.
I would really do the intake manifold as it is reasonable in price and effort.
Kurtis
