Auto Tranny Kick Down
    Hey guys I just droped a jdm h22a and tranny auto.
    All is good till now, when i punch it in any gear it will not kick down to the lower gear.
    And when I take off from a dig and full throttle its shifts at 3.5
    any ones know what the problem is?
    I dont think its the kick down cable because it just happend out of no where, Im thinking a relay or something?
    which cable did you use? we had this problem with a members swap also, the accord cable was binding a little, so we used the prelude one and adjusted properly
    edit:also, how is your tranny fluid, and any tranny codes
    Members Ride
      no codes, but i wonder if its a cable problem, why did it do it out of no where? Is dere any kick down relays or any sort like that?
        cable might be dry, spray some wd40 or something similar in there and see if that helps,
        Members Ride
          should i let someone sit in the car and gas it and check for binding spots? then spray the area?
            i wouldn't recommend to doing it while its running, just have have someone inside press the pedal, even if you don't see binding, spray the inside of the cable, also take a look at the little arm and make sure nothing is its way or if its bent for some reason
            Members Ride
              kool, asides that, is there any other problem why my car wont let me punch it from a dig? first gear i punch it, it shifts at 3.5 and same with second all teh way to fourth
                damn these auto tranny's
                check your fluid and is there any codes for the solenoids?
                Members Ride
