Replacing AC Compressor 93 -10th yr anniversary edition
    Going to replace bad ACCompressor that seized up myself. Saw a new one on Ebay including drier for 225. Once I get it in I will take it to get charged with Freon. Anyone ever do this before? Any info would be appreicated. What I need to know is the old compressor has been out for about a year, so i want to get system flushed. Do Ihave this done before I put in new compressor or after. Also do I add the oil or does guy who is going to recharge system do this. Any tips on doing this job would be appreicated. Thanks
    did you seal off the connections after removing the old compressor? ie:wrapping the ends with a bag?..if so you should be ok..you should consider retrofitting your a/c system to R134A since your going thru all that work anyways..definitely i would recommend replacing the reciever/dryer. the person installing the compressor will add the appropriate amount of oil...remember that when you switch over to R134a you use about 1/2 a lb less of refrigerant as compared to you old r12 system
    1993 Accord EX
    1993 Civic HB
    1994 Integra 4dr
    2006 BMW 330i
    2006 Suzuki GSXR
      Let them vacume out the system and then put in new freon. The compressor should'nt be that hard to put on just a little tricky with the size of it. But once you get it onto the bracket and slip the belt on there it will be a piece of cake after.
