hesitant starting
    hesitant starting
    the problem is in the morning when i go out to start my car it takes a few seconds to crank it also happens when my car sits for a couple of hours.the car is a 1990 with just intake and about 103,000 miles please help
    sounds like a fuel problem...is it cold where u live?
    Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
    -(B-Pillar Bar Originator)-
      Have you checked into the Fuel Filter?
      Street Racing is Lyfe
      Crip is How We Roll
        i have the same problem ,this morning it just wouldnt turn on but the motor turns over...i have a prelude fuel pump so im trying that tomorrow.. if not thenm ill change the filter.
          i live in florida so its not cold. but i havent done the fuel filter so i guess ill change that out and see what happens
            disconnect the outlet line from the filter (filter to injectors)..turn the ignition and see if fuel is going through the filter (make sure u have a friend helping u), if not, then disconnect the other line (pump to filter) and see if ur fuel pump is pumping gas to ur filter.....or vice versa, which ever way works for u!
              funny i just disconnected the fuel line to the fuel rail.. i saw gas come out...l so then i unscrewed the main relay from the bracket turned the key and i felt and heard a click...the motor turns over and its cranking just not turining on... but i feel as if it wants to turn on by the sound... i even hear my muffler..hmm..plugs look good/wires look good/...even if i hear the main relay do that click is there a chance that it still might be a bad part?
                Yes, a relay can click but not complete a circuit.
                And I had an issue with a delayed start fall of last year. I checked everything front to back, inside and out, except the fuel pressure cause I don't have a gauge for it. It eventually fixed itself and haven't had a problem since.
                  yea i guess ill look into that tomorrow and see how much they run for...ive heard that in alot of hot places they tend to mess up...and that on cb7 is a very well known problem..
