H23 and H22 head same?
    I wanted to no if the H22 and H23 heads had the same size components in them. (camshafts etc.....)
    thanks
    Hellz yeah im now workin at HONDA
    nope
    later
    My Members Ride Thread
    You have to think outside the box to get IN the box!
      Originally posted by mcdizzle
      nope
      later
      ok but what is all diferent in them or is it everything?
        one is vtec and the other one is non vtec....the vtec one has diffrent specs of cam lobes....
          does it specify on the head if it has v tec or just from the oil gallories.
            Its different. Cam profiling/VTEC/and head flow. Main differences as already covered. Its not the same it will bolt onto the h23 block but there are differences.
              sooooo a h23 head will fit onto a h22 block with little to no modifications?
                yes
                yes it will bolt but it will be a frankenstein motor- sometimes those are bad! Keep one motor. Just look at the exhaust port patterns- you can see that they're different.
                90-2D 5spd. Turbo/Shaved/slammed/kitted/4200watts/laptop&Tvs...
                Ova 17G's invested in mah AZN ride!
                  Has any one done a h23 head on a h22 block, thats on this site? If so let me no.
                    No...Why would you even want to do it anyway. People go the other way around.
                      Just figured it be sumthin different. I might just try it to see what happens but if not you no. Its whatever ill just try the h23 head on the f22 block. We'll see
                        the camshafts are different, there's more electrics with vtec! look under the valve cover of a vtec and non vtec and you can see
                        Street Racing is Lyfe
                        Crip is How We Roll
