f22b DOHC
    f22b DOHC
    i just purchased an f22b DOHC and i was wondering if there are alot of aftermarket perf parts avail. i have been told to buy h23 parts and was wondering if that is correct. i plan to replace the timing belt , tensioner, injectors, all other belts, among other things pretty much a complete tune up. just wondering if anybody had any info or suggestions. thanks
    Refer to the h23 as your guide for parts, at least I did. I know the heads are virtually the same, so you can use h23 cams and the like. I used an H23 timing belt, and had to mix and match the rest of the belts between f22 and h23 (this was a good while ago so I cant remember exactly what). As for a headgasket? I am not sure what to use. I need one too, so, what do you use haha.
      Use an f22 headgasket, not the h23.
      Turbo H23a3 build has begun
      01-01-2019
