I recently install a AEM short ram intake, and when all was said and done there was a vacuum line left which was not plugged into anything, and it made my idle went a little wonky. it is the short one closest to the firewall. any input would be appreciated.
where does this vacuum line go?
your intake SHOULD come with a place to plug it in, my cheap-O eBay one even has this. if not you can plug it up with some foam or something else breathable that will filter the air a little bit still let it breath. But if your expensive intake doesn't come with a port to plug that line into I'd start some shit with the company and demand compensation, personally.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Originally posted by 91blkcoupeI recently install a AEM short ram intake, and when all was said and done there was a vacuum line left which was not plugged into anything, and it made my idle went a little wonky. it is the short one closest to the firewall. any input would be appreciated.
I have the same intake I bought some vacume line and pluged it into the
little hole near the throtle body. Sould be a rubber O ring that fits the little hole, and a black plastic nipple. I put nipple into O ring and hooked other end to Air boost Beenlike that for 2 years
