Idle problem
    Idle problem
    Hi, messing around website looking for "how to not destroy your speed sensor while trying to remove the **** bolt" ive found that: here
    (http://www.hondapitstop.com/accord/t...le_adjust.html)
    first time i see this, and it might help ppl with their idle problem.
    what goes wrong inside CC units?
    I know the cb7 cruise control computers fail fairly regularly, but does anyone know exactly what goes wrong internally?
    mine is in need of replacement after a diagnosis, yet I popped it open and everything seems to be in order. no obviously burnt diodes/resistors/transistors or anything I could see.
    anyone have an idea?
      nice of u to share that but majority of us already know that!
      Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
      -(B-Pillar Bar Originator)-
        jono20, you should probably make your own thread if you want this question answered. and My unit is all messed up 2, and it looks fine inside, but mine is some no name pos after market unit. I think my problem is in the diaphragm... but you could have a different one. you should go to a junk yard(salvage yard for you yard dawgs) and pull a unit. shouldn't cost much... see if it fixes it... if not you have other problems... and an extra unit to see to someone on ebay or on here
