Transmission or Fuel Injector?
    Hey guys. I just got my 92 Accord LX Auto. I have a question about my tranny because I think its a problem but I'm not sure. Everytime I drive and the car shifts from 1st to 2nd, I feel like the engine pulls especially at lower speeds. I'm not sure what that could be? Im don't think its normal. Any advice?
    Pulls? What you mean by that?
      like when it reaches about 3500rpm to switch gears from 1st to 2nd, it pulls me back. Think about it in the sense of flooring the car from idle. If you go from nothing to the car being floored, you're body is being pulled back. Thats what happens to me when the car switches gears.
        does it feel like your car is being bumped from behind?
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          yea in a sense
            you said it was an auto? it could be your solenoids on your trannsmission.
              well I have an auto tranny. Will I be able to see this if i switch from P to R or from R to D or something like that?
                simplier way to do , forget what I said above..
                when u shift from park to other gears does it move alot? like somthing bumped u from behind? i think its your motor mounts if thats it. check them. if not mounts something from your tranny is bad.
                  I think there's some slight motion if i rapidly change from D to R... but i'll have to get back on you about that one. I don't get out of work til 8 so i'll find out by then.
                    Sounds like mounts to me. When the mounts go bad (and with these cars being so old now, they often do) the rubber no longer prevents the motor from moving. It has a good inch to rock back and forth when the mounts are failing. It would definitely cause a jerk. If the transmission shifts solidly, it should be fine. CB7 automatics have a bit of a harsh shift anyway. If it's harsh, that should be a sign that it's healthy. Transmission problems would probably manifest moreso as slippage... either a delay going into gear, or an unwanted down/up shift at odd times.
