high temperatures
    i'm pretty sure you'll always need to bleed the coolant when replacing the thermostat only because when you remove it you're allowing air into the lines.
    just use fresh 50/50 coolant.
      Originally posted by Mjfan12
      you wont need to bleed the coolant.
      Yeah you will. A lil bit of coolant will pour out. About a quart.
        ok, so the procedure is to start the car, keep the rad cap off, turn the heater on full blast, and lossen the bleeder bolt until you get rid of all the air? thanks, sorry for all the questions.
        1993 Honda Accord EX-R Coupe Granada Black Pearl
        ///Alpine CDA-9847 Head Unit
        OBX Pedals, stock air box, Ebay headers, Stock dual tipped muffler. Emblems removed, grill chrome painted black.
        1993 Kawasaki EX500 Flat Black. First Bike.
          np, hope you get it fixed.
            Hmm..Yo..it may also be something as simple as the radiator cap...check to make sure the cap is still good....it could be something as simple as that!
            hope you figure out whats going on with it!
            92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
            MR Thread:
              Im sorry to keep posting in this thread, but I still haven't done the thermo swap yet, Im very broke atm and hope to get it in a couple of days.
              anyways I just checked my hoses after a hard drive and my upper hose was very hot, and my low hose was cold to the touch so this also narrows my issue directly to the thermo. Or does it?
