spark plugs
    spark plugs
    ok heres the thing i made a block off plate for my egr installed all good ....so i go to check to see if theres any other codes before i clear them and guess what....i got a solid light which from my research means bad ecu which is messed up because my tcu is bad too can you guyz enlighten me please .....also i inspected the spark plugs and they look brand new but the kicker is that i replaced them 2mo. ago so they should have signs of were so im not sure but some thing is wrong please help
    Solid light when jumped with key on on position? Whats wrong with your TCU? Are any of the D4 S lights flashing?
      my tcu ??? my d4 light stays lit constantly ecu solid light when jumped tcu gears dont shift..... when reset the tcu the gears shifts fine and i can drive with no problem so i got that rigged for now .... also when i drive and come to a stop the car kinda wants to turn off but doesn't and i have kinda little low idle surge like from 900 down to 500 and back up at a stop
