right side power window grind after a 1inch of trying to lower it
    i just wanted to know where are the bolt to take the panel off so i can fix this i already put 16 inches rim on and tint but it doesn't make me happy untill i fix this problem and paint it
    4 door ex-l
    There should be a screw behind the door handle.
    Then there is one like on the part like where you grab your door to shut it if that makes sence.
    And the last screw is in the bottom corner and since its the right side it should be on the right bottom corner then. I believe thats all of them, and make sure you take the door handle off.
    Hoped this helps
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      This might be helpful...
      http://www.cb7tuner.com/vbb/showthread.php?t=37216
      Member's Ride thread
