ok aside from the steering wheel shaking now i have another problem my tach,speedometer,temp guage,allmost all the lights in the cluster dont work aso the rear defrost but the hazard does and turn signals also the cluster lights up when the headlights are on like normal . when i press the brake to go from p to d it wont let me its locked like if the car was off i know it cant be a fuse so i looked at the wires all 3 plugs are in on the cluster also looked at the 3 plugs behind the radio they are all in is there a relay or something im missing please someone help
Heres a good one
omg, that is a laundry list of electrical issues, and a handful of mechanical issues.
At some point all that amounts to not being worth fixing.
Pull the dash cluster and make sure its plugged in completely. should be 3 plugs. One on either side of the cluster and one behind the top.
Good luck with the rest.
good greif, and I thought I had electrical issues.I cant Slam further. The ground refuses to get any lower.
So what were you messing with first before all this happened. There is a fuse for the dash check that. Its like number 13 in the under dash fuse panel see if thats blown.
Originally posted by Akira_kjomg, that is a laundry list of electrical issues, and a handful of mechanical issues.
good greif, and I thought I had electrical issues."Back in the cb7 game"
noticed my clock is not working either to heres a list for shit that stopped working all at one time cluster,rear defrost, dash clock,car wont let me go from park to another gear even when hitting the brake the only way to change from park is to put the key in the hole next to the gear before i start the car, last but not least the timed wiper all other settings work. im going to remove the whole dash tommorow anyone know of a plug or ground that controls all those things i have the haynes book and it does not help.someone please help a fellow cb7 owner out"Back in the cb7 game"
