tranny help
    tranny help
    I have a h22a with a 91 of 92 dx tranny. The guy I brought it from said he forced it in. The problem is the tranny is not sitting straight. He said it is touching something I forget what it's called. But I could hear it rubbing. Can anyone help me I don't have the money for a H series tranny the tranny is fine I just want it to sit straight.
    is it an auto or manual tranny?
      it's a manual used to be auto
        it might be the tranny mount thats the culprit...if he didnt line it up right when he did the swap then its going to be off
        Originally posted by fizzbob7
        Originally posted by ACC0RD22
        So. Cal OUTLAWZ
          he said that I could get the mount tapped or something like that. Some kinda of modification to the mounts. The motor runs great and everything shifts fine. It's just that the tranny is not aligned straight is slanted.
            well if the tranny isnt straight then youre going to go through axles like no tomorrow...you might have to remove the old tranny bracket from the car and reweld a new one to make it sit like its supposed to...thats if he didnt do that to begin with
            So. Cal OUTLAWZ
              When you mean not sitting straight you saying he didnt shim the mounts and shit properly since that is what your supposed to do with an auto-manual conversion.
                my PM:
                hey man.
                when people convert to 5spd, they usually use a prelude transmission mount to make the motor sit straight, but that kind of mount only fits on a prelude transmission (h22) or a 92-93 EX tranny. a DX one wont work... the only way to keep the tranny you have straight would be to cut the old bracket off the engine bay and weld on the proper bracket onto the side, so it matches the size and location of the mount that is on top of your transmission. or buy a new prelude transmission and get a prelude mount, and add a couple washers to make things line up.
                http://www.explicitspeedperformance.net/ is almost done creating a perfect mount for converting a CB7 to 5spd, but again, itll only work with prelude and 92-93 EX transmissions...
                - mike
