car wont start
    You should've gotten a new Main Relay. They're only 40 bucks. Getting these types of parts from junkyards aren't usually ideal. Sounds like its your relay or ignition coil...that or a bad starter,ground wires, etc.
      As someone said check the t-stat ground. You dont need to buy a main relay there is a cheaper method which you just resolder the insides and its useable again. I would check your ground to t-stat if all else fails you got a dud for the ecu. If I remember it goes ECU-coil-dizzy-plug wires or something like that for the wiring diagram gotta check that out again.
        How do you check the t-stat? With a test light or some thing else?
          i say its the distributer
          93 accord: F22A swap,T3/T4 turbo, tail wastegate, front mount 27x13x3, hks turbo timer, turbo xs boost controller, msd igintion, 3in downpipe, crane cam 11mm plug wires, denso plugs, no ac or ps,wire tuck, cutted insides, one seat, auto meter boost gauge,oil pressure, a/f,and 5 in tach,act clutch and flywheel.
          93 prelude: jdm headlights,OEM carbon fiber hood, tein lowering springs, work racing rims with kumho tires, msd wires and denso plugs,type r shift boot
            I for got to mention that my transmision is realy bad, The TCU is throwing codes 1,2,3,7,8, & 14. Could the transmision have anythindg to do with the car not wanting to start? sorry i didnt mention this earlier
            Thanks for the help
              Please help
                I read on here that some guy also had no spark and it was because his fuel injectos wrent working? could this also hapen if the fule pump aint working? I use to be able to hear the fule pump hum before i would turn the car on, but now i cat hear it no more. I thought it was because of the main relay but i bought a brand new one yeserday and i still cant hear the fule pump.
                Also what does it mean when the check engine light stays on?
                Thanks
                  Ttt
                    BTW, a soldering gun is about 16 bucks along with wires next to the gun in a Radio Shack store. Just got one! The only downside, is that mine didn't come with instructions, most likely cuz it's not that difficult to use.
                    *Needs*
                    -New shocks
                    -Struts
                    -Drop
                    -Cleaning
                    -New Tires/Wheels
                    -New Window Tint
                    -Alot more lovin'
                      The one reason why your fuel injectors aren't workin' is PROBABLY cuz of the quality of gas in the first place. Just a word of advice...DO NOT GET GAS FROM QT (QuickTrip) OR RACETRAC..bad quality. This was what caused my fuel injectors to fock up and forced me to get em cleaned out!
                      *Needs*
                      -New shocks
                      -Struts
                      -Drop
                      -Cleaning
                      -New Tires/Wheels
                      -New Window Tint
                      -Alot more lovin'
                        Na man, my fuel injectors are working fine. I was just saying that some guy on some other thread had no spark and it was because his injectors wernt working, i dont remember to well but i think it was because of a bad wire behind a fuse or something. And i was wondering if a proplem in the fuel system would cause the engine to have no spark, because right now i cant hear mi fule pump hum and im thinking that might be whats wrong with my car.
                        Thanks for the help
                          Originally posted by brownlx
                          My car wont start because it gets no spark, i searched and and i it said it could be the ignitor or coil, but since i found alitle bit of oil inside the dizzy i just replaced it with a new one but the car still wont start. I dont think its the plugs or plug wires because they are still kinda new, but who knows that could be it? Also the check engine light stays on, it doesnt blink it just stays on. I tried looking for codes but i got nothing. Any help would be greatly apeciated, thanks in advance
                          Edit: I forgot to mention that the new dizzy came with a new ignitor and coil
                          Check your ignition timing afterwards?
                          Code 0
                          faulty ecu. Check the main ecu electrical connector and check that ground on the thermostat housing.If those check out, take off your ecu and take to honda and have them check it or get one out of the junkyard.
                            Totally, check that ecu main. Peace
                            Keep an Eye on my Coupe. Click the Pic
                              it crank??? maybe no gas? gas pump? kill switch from the alarm (relay went bad) ?? check all ur fuses? u accident disconnected that amplifier lookin thing by the power steering pump in the engine bay? ignition coil? dead battery? stolen spark plugs?
                              DEFJAM
                              MY RIDE ON CB7 DEFJAM on 93
                                Well I got a new ecu yesterday, well not realy new its from a junk yard, and the car is still the same. The only thing i can think of now is a bad ecu conector. By the way the check engine light is always on not just when im looking for codes, what does that mean?
                                Any way thanks alot guys youve all been a big help
