jdm H22 help
    jdm H22 help
    hi just a quick question. i can get a h22a4 pritty cheap and its gioing in my 88 crx what the diffrence for the h22a4 and the jdm h22a and sould i spend the extra $400 for the jdm?
    thanks
    probally the milage jdm motors usually have less than 40-60k, most usdm usually have like 80 -100, but if the price is right go for it. not much differance .
    FS: DSM turbo parts,OEM parts, and more.....
    My Members Ride Thread - R.i.P
      Compression is a little higher for h22 jdm motors which produces a a little extra horsepower and as mention above, the mileage is usually lower.
      ...adjust accordingly
        the h22a4 is the usdm version i think and it has a little bit less power than the JDM h22. If i remember correctly it is obd II as well.
          yea, make sure you get a conversion harness, i'm pretty sure all h22 motors are atleast obd1, and crx is preobd so yea. also a cable to hydraulic tranny conversion kit.
            Put in the H22A4 its the same basically still rated at 200hp but compression is lower as mentioned. They had a few that were 190 in the 97-99 model year then they started putting the SH 200hp in the base ludes if I remember something like that. Anyway back to your question you can get it you need to convert to obd1. You dont need a harness. Pick and pull the dizzy, ECU, injectors, and such and it will be back to obd1 basically. As for spending the extra 400 as mentioned it depends on if you want a lower mileage engine or not and if its worth it to you.
