I'm sure this is nothing but i thought i would ask anyways, I changed all my interior lighting to LED lighting and had a little bit of an issue with my cluster, I pulled it all apart and changed to LED's, tested the bare PCB before i put everything back together to make sure all my LED's were in the right way, all tests were good so now I can reassemble my cluster, here is where i ran into the problem, I happened to strip a screw on my temp gauge (1 of the 3 screws that holds the gauge to the PCB and now when i start my car my temp gauge goes right to max and my check engine light is on.
should i be worried about the light or is it on because my gauge is now broken, i'm going to go to a scrap yard to get a new gauge soon because i'm not sure i would find a CB7 buried under the snow right now so i'll have to wait.
