when I turn my ignition switch on the gas gauge goes all the way up and I only 5 gallons in there also the temp gauge rises after having the car on for 1 min. I have replaced all the sensors and all connections are good so I'm lost, also the indicator of weither or not a door is open doesn't work. help.
stupid electrical
Originally posted by nuclearawhen I turn my ignition switch on the gas gauge goes all the way up and I only 5 gallons in there also the temp gauge rises after having the car on for 1 min. I have replaced all the sensors and all connections are good so I'm lost, also the indicator of weither or not a door is open doesn't work. help.
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
haha add or remove? well I put a f22b in their reused the stock wiring harness(labeld all the wires and connectors), removed the a/c, p/s and put battery in the trunk removed carpet put new black one in removed back seat 3 point seat belt conversion, gauges where the radio was, other than that no not really.o I did replace the gauge with one from the junk yard, no dice still not working right.
