okay I read the DIY for Valve Adjustment on this site and in the helms manual..to get to TDC on cyl 1, the book said turn the pulley clockwise for #1 and the rest is counter clockwise.....or its suppose to be counterclockwise for #1 cyl at TDC?
TDC - counterclockwise or clockwire??
ok for cyl #1, there should be 1 dot on your top gear and another on the lower, line these up and your #1 cyl is TDC, now as for the others, its a 1/4 turn on the top gear for each cyl.. just get the firing order, and drop a rod down the spark plug hole to see if it is all the way up, or use a flashlight and look down it and see. best way to do it. I did it on my 3rd gen accord and it ran alot smoother with the adjustments I made and was quick doing it this way except mine was side mounted plugs so I had to feel the piston with my pinky.
Originally posted by DFRHondaok for cyl #1, there should be 1 dot on your top gear and another on the lower, line these up and your #1 cyl is TDC, now as for the others, its a 1/4 turn on the top gear for each cyl.. just get the firing order, and drop a rod down the spark plug hole to see if it is all the way up, or use a flashlight and look down it and see. best way to do it. I did it on my 3rd gen accord and it ran alot smoother with the adjustments I made and was quick doing it this way except mine was side mounted plugs so I had to feel the piston with my pinky.
MY 1n2 CB7
ok, first take out all your spark plugs, it is much easier to turn....
put a long screw driver in number one... bump the starter by jumping it with a screw driver until the screw driver goes all the way up and starts to go back down. but a socket on the crank and turn back until it is all the way back up...
top dead center awaits you...
and to really answer your question.... I wouldnt turn counter clockwise, because you may loosen your crankshaft bolt.
I always turn my engine clockwise.
Originally posted by dean_harrymanok, first take out all your spark plugs, it is much easier to turn....
Originally posted by dean_harrymanI wouldnt turn counter clockwise, because you may loosen your crankshaft bolt.
But anyways........ ......I just noticed the title to this thread, was funny at first but did anyone notice it says clockwire??? Just wanted to tease about it lol. DW, I do things like that once in a while too haha, u aint alone
Originally posted by DFRHonda......I just noticed the title to this thread, was funny at first but did anyone notice it says clockwire??? Just wanted to tease about it lol. DW, I do things like that once in a while too haha, u aint alone
