what year model prelude did the h23 come out of??? and is it a direct drop in, meaning, can you use the f22 harness, ecu, mounts, transmission, ect. thanks.
h23
4th gen lude aka 92-96 but doubt you want the 96 since its obd2. You can use your harness you have to wire up a knock sensor. Its direct drop in like any other H series swap. Look in the swap faq for the holes you have to tap for the trans,
the H23 comes from the Honda Prelude SI model. if u want to use the F22 tranny, you will have to tap it as already stated. The ECU from the F22 wont work because of the differences in the 2 engines such as compression ratios etc.
As for the B20 from the 3rd gen. Prelude, it doesn't produce enough power to make the swap worth it. hope this helps.Originally posted by deevergote.And please, for the love of God, type like a human being!
Originally posted by 91 EX-Rthe H23 comes from the Honda Prelude SI model. if u want to use the F22 tranny, you will have to tap it as already stated. The ECU from the F22 wont work because of the differences in the 2 engines such as compression ratios etc.
I droped an H23 in my car. As stated the knock sensor needs wired up. Change to a P14 ECU. The wiring i had no problems except the egr valve. Just use the f22 egr. And for the tranny i used the h series but i didn't have to tap any holes. I used the 5th gen accord tranny mount. The holes line up and bolts right in.
Originally posted by H23CB7I droped an H23 in my car. As stated the knock sensor needs wired up. Change to a P14 ECU. The wiring i had no problems except the egr valve. Just use the f22 egr. And for the tranny i used the h series but i didn't have to tap any holes. I used the 5th gen accord tranny mount. The holes line up and bolts right in.
The 3G Accord had an A20. The JDM B20 (also Accord, I think) is a pretty decent swap for them, but they're hard to find in good shape now.
The 3rd gen Accord and Prelude motors are not swap options for us, even if we would want to use them. It would take a rediculous amount of custom work to install one, and the power potential (and VERY limited aftermarket) just isn't worth it. Honestly, if you're going to do that much fabrication, a K series or a V6 swap (both of which aren't doable for us... yet...) would be a much better choice. Hell, a B18C would be a better choice! At least there's enough aftermarket for one of those to make some power!
As for the H23, 4th gen Ludes, Si trim. They're good motors, but rather overpriced these days. Aftermarket isn't as strong as the H22, and I don't believe they used them in Japan (meaning you could potentially have a high mileage motor... not worth the money it would cost). F22B DOHC is the better choice if you don't want to go the H22 route.
Originally posted by NAiL05You dont have to tap the stock F trans...I was talking about the H series trans. B20 is a POS in those accords. There are diff b20 one in the crv and the POS that came in the 3g accord that isnt worth a damn.Originally posted by deevergote.And please, for the love of God, type like a human being!
