i am ganna be building up one of my f22a blocks and building the engine for turbo and i am ganna be doing a head swap what would be the better head swap to do the h23 or the f22b?
what is a better head swap
Either one there the same.
x2, and get a h23 intake mani for the better air flow**Blk Housed Slut Crew Member #1**
F22B/H23A1 will give you more room to play around with. Especially with the DOHC instead of just a SOHC. Makes adjusting timing easier.
oh god, the new myth that the stock f22a head is "sumthin' special".
it flows well, so do 99% of the other import heads made since 1990. it's a misleading statement. from what i've seen, the f22a head doesn't outflow the f22b or h23a1 head at all, and the only real difference is that it's a SOHC head which means it's less likely to be dialed in perfectly.....and on the 7th day, deevergote rested and called his mom.
