Originally posted by djcaz_aom
Jerking
Originally posted by accordaffairYou should clean the service ports, egr valve is not as important.
The egr port clean procedure is pretty complex. Actually, there are couple of different ways to do it. I had my intake runners out so I was able to pull the service plugs (little brass plugs behind the fuel injectors) and actually flame clean the ports by shooting compressed oxygen into them. But in car, that is pretty dangerous, you can take the intake out, and find some with an oxy-acytelyne rig to do that, to you can resort to the old pick and brush method. Also, remove you EGR valve, and clean around that, try and clean back into the head too!
To remove the brass service plug, what i did was to screw a little screw into them, the are soft being brass, and use a claw hammer to yank them out. According to the book you only need to pull four of the six, the four that are closer to the firewall. Make sure you have replacement plugs before you do this (avaible at some parts stores, Dorman makes them) and an EGR gasket, I dunno about aftermarket, but readily available from Honda!
Hope that helps.
how do the fuel injectors sound? this is kind of a stretch, but if you put a long screwdriver up to each injector, then put your ear to the handle, you can use it like a stethoscope (unless you have a real auto stethoscope, )
They should all sound the same. Listen at idle and try playing with the throttle, at some point the engine will drown out the sound though....
Was the fuel filter you replaced OEM?
I'm kinda just throwing things out there now...
it only happens while driving or does it miss when revving in neutral too?
My friend and I have this problem and I really am leaning towards the fule as it just seems that there is a lack of fule pressure going to the injectors at lower or now throttle. Mabey have somthing to do with the fule pressure regulator? Or like was already mentiond clogged or porly functioning injectors.....my fule filter isnt OEM but Ive seen oem and there doesnt seem to be much of a diffrence.also its bran new so thats not the problem as the problem never worsend or got better after I put that in. Im going to remove my injectors and clean them up and listen to them for pulse
I had a lot of problems with a brand new non-oem fuel filter from autozone, not all are bad, but OEM is usually always a good decision.
You can test the regulator, see here....you'll need a fuel pressure guage
http://media.honda.co.uk/car/owner/m.../400/6-213.pdf
Also here is the service manual page for that injector testing I was talking about
http://media.honda.co.uk/car/owner/m.../400/6-210.pdf
Oh and djcaz_aom, here is a troubleshooting guide for the fuel delivery system...
http://media.honda.co.uk/car/owner/m.../400/6-208.pdf
