Jerking
    Jerking
    Hey, I was driving today and noticed that when I am in the low-rpm range, my car starts to jerk like it is about to die. Does anyone know what is wrong with it? I havent the slightest clue. Please help me. Thanks
    91 Coupe-Under Construction
    is it 5 spd?
    "This truck is 100% sh*ts and giggles."
    "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
    You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
    Disregard females, acquire currency
    BUS 62 AIN'T F'ING AROUND!
      Manual or auto?
      Does your idle bounce around in neutral (say from 800-2000rpm)?
      Does it completely die if you don't give it gas?
      It could be the generic "surging idle" problem along with old motor mounts.
      - Ghosty
      WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
      FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
        Sounds like the issue I've having, but 10 times worse. I suspect a tiny vacuum leak or EGR issue, but its mostly a guess.
        Sorry I can't help anymore, but if I uncover anything, I'll be sure to let you know.
        Hopefully someone can set us in the right direction.
        Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
          Sorry I wasnt clear earlier, its a 5 speed. The idel doesnt bounce around it just feels like the car struggles after the shift. I think is could be an ignition problem but not really sure.
            Is it only in the 1500-2500 range under low throttle?
            could be clogged egr ports
              Hows your tune up.
                my friend had the exact same problem in her car, i think.. its in low range rpms, and it does it worse when you give it more gas, right? you might wanna check the spark plugs, wires, or distributer. hers were the plugs themselves.
                R.I.P 90 lx fodo ..my baby!
                R.I.P 00 DC2 gsr
                R.I.P 92 lx fodo
                R.I.P 91 dx fodo
                rockin a 2007 ridgeline rtl
                  Hmm...that does describe mine, except it always clears up at 2,000, and doesn't always do it. Perhaps a lazy EGR valve or starting to clog? All tuneup stuff is semi-recent or checks out OK. Mine's also a 5-speed. I'm gonna keep an eye on it and see if the behavior changes with gas, temps, etc. See if I can find a correlation.
                  I'll be able to check accordaffair's hypotheses when I get my new IM on.
                    ok guys, thanks. I will check the spark plugs and distributor cap and ect. I have been keeping it pretty well tuned up so I dont think that is the problem but who knows. When I give it gas, it does jerk more sometimes and sometimes it stops.
                      This is my problem right now and I have done the following with no Luck:
                      1- New dist cap and rotor
                      2- New wires
                      3- New NGK Iridium Plugs
                      4- New fuel filter.
                      5- Cleaned out EGR Valve with carb cleaner
                      Does anyone have any ideas on how to fix this problem?
                        You should clean the service ports, egr valve is not as important.
                          Agreed.
                          As a test, why not disable the EGR valve? See if the problem still occurs.
                            i just had that like 1500Rpm and under lil jerk. i changed my oil. [put in syn] and changed my tranny fluid. and it didn't do it. till just befor my next oil change.
                            cheers
                            My Ride...
                              cheers
                              I've done that too. I'm going to do the service ports tomorrow and see if it cures it.
