distributors
    distributors
    Are the dizzy's off a 91-92 interchangable?
    both cars are LX's
      No. Simply because the 92 will have an external coil. You can however convert between the internal and external coils.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        if youre going from 92 dizzy to a 91, then its cake. all you gota do is splice the thick yellow and black/yellow wires that go into the external coil(its on the cars harness, not the dizzy harness)
        but if you're going from 91 to 92, its a bit more work cus you gota rip open the distributor and take some wires and blah. its not hard, it's just intimidating for some. there are write ups all over the diy section on how to do this. although, the diy's are done with aftermarket coil, you should be able to do it with a stock external coil too.
