I've tried search but can't seem to find what I'm looking for.
I want to say that I read somewhere that you can "reset" your map sensor? Is this in anyway correct or make sense?
I've done about all there is to do w/ my idle and its damn near perfect but occasionally I get a slight fluctuation (1000rpm-1500rpm only in park or neutral).
Ok, I'll just go ahead and say what I think I read (as ridiculous as it may sound). I was thinking that I read somewhere that you can "reset" the MAP sensor and then it will "re-learn" the idle. Sorry if that sounds completely stupid.
probably the same as just resetting the ECU...I don't know. Be gentle with the flames.
