ecu?
    i'll clear this up for you. There are two types of ecu's in the cb7's. The PT3 and the PT6. The PT3 is for the 90-91 lx, dx, and ex. Its also for the 92-93 lx and dx
    The PT6 is for the 92-93 ex and se.
    Thats all you need to know. either will work perfectly fine. You won't even be able to tell the difference.
      Auto ecus work the same. Thats why there is a tcm for autos.
        thanks guys. ill post the real problem once the mechanic can figure it out. thanks again for all the help.
        Sig removed due to excessive size
          this is good i guess
          http://www.cb7tuner.com/vbb/showthread.php?t=56836
          from what i read there, a chipped 92-96 civic's obd1 will work? i deno, i don't really tune my car to go fast, especially when i gotta spend all my money just to keep it running! lol, good luck. cheeow
          *edit*
          oh yeah, and before someone goes OMG WTF BBQ, i just admitted I DENO! so go away if you're not going to say something to help this guy.
            thanks jayrq2o1. that info is very useful, but it is making me want to beat my self as well. i just sold a 93 civic hatch to a guy about two months ago. damn.
              i've got one that i can send you now. But maybe you should rethink the trouble shooting process because your problems don't sound like the ecu.
                wha does it sound like to you MRX???
                  u haven't given nearly enough information for me to diagnose
                    ok. i bought the car for $500. it had a broken camshaft so i just went ahead and replaced the whole head. i tried to crank it up and it turns over strong but i dont get any spark.. i swapped the dizzy with a known good one (literaly took it off of a friends accord and tried it on mine and mine on his, mine worked on his). still nothing. i tripple checked all of my wiring and everything under the hood. new coil, igniter, rotor, cap, wires, and plugs. main relay is good. when i turn the ignition on the cel dosent come on. in fact, none of the engine lights come on. ive checked the bulbs and they are good. thats why im suspecting the ECU. i hope that this is detailed enough.
                      You check the thermostat ground?
                        im going to when i get off work. it goes from the dizzt to the im right???
                          nope, its on the bottom of the thermostat housing. Its the ecu's ground wire.
                            also...if u were able to swap distributors with that friend of urs then try his ecu also.
                              ok, here's an update. i checked the thermostat ground and it was loose. so i tightened it up and lo and behold the check engine light came on, but its very dim. and the car still wont start. i havent checked for spark yet. what would cause the cel to be very dim???
                                X2
