im new here but check it out! for you guyz that have an idle prombem do this .......let the car warm up to the point that the idle starts go up and down with the car runing take intake tube off and you'll see two suction holes inside throttle body before tps put your finger on the bottom hole and surging will stop if so plug hole you can fill hole with j-b weld or you can cut a peace of aluminum plate bent to fit the contour fo the throttle body and stick it on with rtv and let it dry replace intake tube and start her she should be ok let me know if this helps
idle
What da pho...Why? When you can fix it without having to put crap like that in your throttle body???
