i have a supsension question... i read the sticky in the suspension section... what exactly is the suspension setup on and CB7? struts in front and shocks out back or both on all 4 corners.... just trying to get a lil more knowledgable about my CB7... thanks guys
once again search only answered part of my question
Struts and Shocks are basically the same thing...And yes the car has 4. We run on a wishbone setup. Its similar to the mcpherson (sp?) setup but the bottom where it goes around the axle is different.
Struts all around... most peope use the terms interchangably on here anyway.
Our setup is similar to the MacPherson setup, as said above. The main difference is that the suspension geometry doesn't rely on the spring/strut combo at all. I learned this when I had the great idea to use adjustible pillow-ball mounts to change my camber... it won't work.
I thought we run just a typical double wishbone up front. Because our setup is not really like a MacPherson setup at all. Except the fact that the spring goes over the strut.
The term strut is used when the spring is sleeved over the shock. When the shocks are mounted separately from the springs then the term shock is used.Gary A.K.A. Carter
[sig killed by photobucket]
Originally posted by The G-ManExcept the fact that the spring goes over the strut.
