I have code 36 (traction control).How do i fix it?Also im throwing 2 other codes 22 and 23(vtec pressure valve and Knock sensor) I'll greatly appreciated if some one could shoot me a thread or give me some info on where to start.Oh yeah im running a P13 with my H22A.
CEL code..?
Its manual, and its reving between 1300 and 800 rpm or some where around there..only when the engine is warm.It revs back and forth.At first when i had the vtec and iab stuff hooked up CEL went away.After driving it for a while it came back on.Turn off car, turn car back on its gone.Only while driving will CEL come on.Mahn i'am lost.I have been driving it for a week already nothing seems wrong except that my vtec aint working.I'll double check my wires and pin locations.If the knock sensor is failing will i feel a power lost or other symptoms.
Is there a way to check and see if KS and Vtec pressure valve are still good?Hybridnation
KS will hinder performance as you have noticed. It will retard your timing. Recheck your wiring see if you got them in the right pins and such. Traction control I think thats just with the ECU you are using probably. Anyway recheck the wiring first, make sure everything is grounded properly and then see whats up.
Finally check and made everything wired up properly.Check engine light is gone, but there is another issue.Im still getting 22 23 36 codes.When i get on freeways my cel comes back on.Got back home shut off the car and start it up and cel is gone again.Plug in pin to check codes and its still there.Unplug and no cel.Drove around the block no cel.Weird huh...only comes on when i go over 50mph i guess.Can it be that my knock sensor is bad and its causing my codes to give me vtech pressure valve also?Car is running fine after three weeks of firing up and driving around.Anyone run into this problem and had it fix help me out please.I dont wanna waste money on a new ks and vtec assembly.ThanksHybridnation
