Can you swap engines between AT/MT???
    Can you swap and an engine from an AT car with the engine from a MT car hassel free? And vice versa? Can this be done without alot of modifications?
    The Lord watches over me!
    - D. Chappelle
    yup you can just gotta switch over the tranny and get the axle for that tranny cause theres one axle thats different between the auto and manual trannies on the accord also gotta get the tranny mount cause there slightly different between the 2 transmissions
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      so the engine out of my '93 SE AT will bolt right into a 93 EX MT and run properly. A tech that likes Honda's and Acura's at my Mercedes dealership said that he din't think it was possible. Please ya'll let me know if you can do this.
      - D. Chappelle
        yes itll bolt right up and run just fine
        PSN ID's:Tidashoni
        My FS Thread
          oops forget what i said about the axles and tranny mount i was thinken you wer gonna to an auto to manual tranny swap lol
          PSN ID's:Tidashoni
          My FS Thread
            its not that simple cause the position of the auto tranny is not in the same location its a couple of inches off u gotta get the bracket cut and weld @ least thats wat i was told im doing the same thing but the other way around
              yup u can....my dad has been a Honda Mechanic for allmost 22 years and he said it'll bolt up just right without a problem.....and yes ur suppose to change on of the axel...the passenger side i believe and the tranny mount!
              Signature removed due to excessive size. Please read the rules before creating a new signature. - cp[mike]
                no the engine are exactly the same in these two trims both are F22a6's
                PSN ID's:Tidashoni
                My FS Thread
                  hes talken bout just switching over the engine not tranny guys
                  PSN ID's:Tidashoni
                  My FS Thread
                    ok i get it now
                      so is this possible. My 93 SE engine has only 91XXX miles, and the 93 EX engine has way more miles. My engine is very strong and reliable, so I want to use it.
                      - D. Chappelle
                        IT doesnt exactly bolt on...YOu gotta remove the flexplate that was on the auto motor then you gotta get a flywheel and clutch assembly. After that you can bolt together the trans. As for the mounts you can use a 5th gen mount and shim it. I dunno if the ESP company has finished fabricating mounts but yea. The better way is to chop a mount bracket off a 5spd and weld it on.
                          Thanx. I found the answer on the swaps forum. My bad, I should've have looked haeder 1st.
                          - D. Chappelle
                            cool, just dont forget to switch the flywheel out
