newbie help
    newbie help
    okay i want to remove my valve cover so i can change the gasket and possibly put in a new cam seal... 1. where exactly is the cam seal is it on the timing belt side or the side where the dizzy is? 2. can i get to the seal by just taking the valve cover off?
    3. okay what kinda tool do i need for this job i used a regular 3/8" drive ratchet with a socket and the bolt wouldn't turn for shit...
    4. do i have to torque everything down if so to what lbs?
    5. the balance shaft seal i want to change also.. do i just take the timing belt cover off and slide in a new one?
    thanks guys..
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    thanks guys..
    1. not sure...bump
    2. don't think so...I think you have to remove rocker arm...bump
    3. socket wrench set, crescent wrench set, 10" socket extension, sparkplug socket, craftsman torque wrench, flat head screw driver, feeler gauges (0.012 and 0.010)
    4. this thread and this thread
    5. don't know, bump
    sorry kinda noob but hopefully I helped a little.
    91 EX F22A4 - Stock w/ 220k mi
    My Ride - 12/06
      bump
        For the valve cover, you just need the proper sized socket. I forget the size, but it's a common one (10mm, maybe?)
        Remove the cover, replace the gasket, and use the proper sealant over the cam humps.
        The other tools listed in OptimusPrimeSr's post are for more involved work, like a valve adjustment.
        The cam seal is on the dizzy side, I believe (a quick look in one of my manuals would answer that for sure, but they're in my car... and it's 12:24am, snowing, and I have no shoes on )
        Balance shaft seal... I actually need to know that one myself! I have to do that before my motor croaks...
          bump anyone wanan give anymore tips?
            ttt
