Another lowerind ?
    Another lowerind ?
    I've read around the site for a while and kept seeing people say that if you lower your car with springs but still have stock struts they will blow. but on the wiki site ( http://www.cb7tuner.com/wiki/index.php?title=Springs ) it says certain springs can let you drop your car as low as 2" on stock shocks. so my question is which is accurate?
    Once you pass the 2" drop you either need brand new shocks to really last, or good condition used ones. Some shocks last quite a while with over 2" drop and some dont. But the safest thing is to get the shocks that can handle the drop.
    With a 2" drop KYB GR2 is very good with ride comfort and price
      As mentioned its a matter of time and how good your shocks are. I am on a 2.25" drop on stock shocks. i can tell you its starting to sag and its noticeable. What I would recommend is getting a new oem or similar shock or an aftermarket which willl last a longer time with the drop. After that you should be set. And depending on how low you go you can get a camber kit but thats optional.
        springs
        my car is lowered with eibach sportlines with stock struts.its only been lowered for about 6 months and im getting some sagging and rough ride as well.i would recommend doing the struts when you lower it to save you having to take it apart in a cople of months
          aight thanks guys
