i have a 92 accord ex auto and when i get on the gas good the tach goes up to like 4k rpm and then it bounces all over the place and if i stay on the gas it doesnt shift when it is suppose to it keeps going and then it back fires and then shifts into second and then it seems like there is a govoner that kicks in when im in second...i know its a bad discription but any help would be great thanks
92 accord problem
kind of sounds like a fuel delivery problem, but hell if i kno man, good luck"This truck is 100% sh*ts and giggles."
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
Disregard females, acquire currency
BUS 62 AIN'T F'ING AROUND!
If tach is flying everywhere when you gas it ignitor lol.
Originally posted by AbunDiga909its probably just the ecu.. if you reset it to the cosine of your tourqe over your horsepower, it should reset so that it releases well w/o the gas...
if that doesnt work, which it should, i just did it to mine, graph your torqe/hp ratio on a dyno and then find the amplitude of your new cosine graph of the torque... it should work.. lemme know how it goes..
p.s. this is what part of the alphabet would loook like if q and r were illiminated
Originally posted by AbunDiga909you know what... mr. HAHA let them laugh... you really dont knwo much, do you? get your arse off that lake and try what i said.. you will learn my friend.. you willl learn
p.s. this is what part of the alphabet would loook like if q and r were illiminatedMy Member's Ride Thread
Originally posted by 19dabeast85He's BS'ing around. That makes absolutely no sense. Even if it did apply, it's mathematically irrelevant because the max amplitude of the cosine wave is ALWAYS 1. Learn a little calculus buddy!
okay, i know this might sound really dumb. but check your coolant levels, bleed, top off and check for leaks. even the most miniscule leaks will cause all kinds of crazy sh*t to happen. i had a tiny little leak from that small house on the thermostat housing that goes up and God knows, i forgot, but my dad's the mechanic, and he said, "oh, there's your problem." and i was like, "get the f*ck outta here, a leak...is causing my transmission to be ***?" but lo and behold, he cut it, moved it down, reclamped it. i started, drove and never had the crazy bouncing tach again. have since replaced every hose in my system and still running strong.
just a thought though, ignore if you've done that already.
*edit* haha, there's a small house on my thermostat housing! lol, i guess i meant hose. its 9 in the morning and my coffee isn't working.
