Idealing sheity
    Idealing sheity
    I need some help.
    When my cars in park. I hit the gas n then i let go. The ideal drops then my car turns off. When in the morning the ideals fine when start up then the ideal drops then feels like its about to stall. so what should a do. should i adust the ideal or sumthing
    I have the same problem. but mine idles at like 1500 rpms jumps up to 2000 then falls back. and the weird thing is it only does it after a hard drive or if the car has been on for a while. there are other threads about this. so you may wanna try searching.
      search please
      search before posting please...but heck, here ya go..
      http://www.cb7tuner.com/vbb/showthre...t=erratic+idle
        Originally posted by 1993hAccord
        I need some help.
        and i believe its spelled idle, unless there's another spelling from another country i've never heard of.
          i can answer that. three things can affect that but the main problem is the idle speed is too high. adjust it so it is around 650-800 rpm's. if it still does it then replace your "fast idle". if still but unlikely it still has a problem then its your "idle air control valve" (iacv).
