Back passanger window stops about 1/2 inch from top. no blocks in the guides in the upper part of the door when the window is up, and none in tracks. Any ideas? oh yeah power windows.
Window Problem
Umm you try "helping" it up a lil does it go up higher? Does it work when you move up and down buttons?
Originally posted by NAiL05Umm you try "helping" it up a lil does it go up higher? Does it work when you move up and down buttons?Vinyl stickers, graphics, car magnets, window adverstising, logos, club stickers, banners, etc. Need em I can make them. Email me at .
Sup. Take out the door panel. It is easy to remove and reinstall it containes 5 screws. There will be a plastic liner on the door skin. Cut into in a manner in which you dont destroy it . Down the middle. And Across. Then You'll see that the window motor guide has been melted by the metal cable that runs the rollers. This Happend to both of my rear windows. I had them removed And installed a Brace so the windows wont roll down. i think this is a common problem. N E way now you can ride super dark tint on the rear since they dont roll down. Ever seen those delta 88 's with real dark tint? Ther rear windows cannot be rolled up or down and its legit. Legal.
yep that sux
Sounds like your motor and switches work guy. So just dig in to the door shell peep the cables and see if they have cause friction to the plastic guides. (pretty shitty design if you ask me) Try to salvage ti use gorrilla glue or plastic jb weld and re use it . Again the motor and cables and swithes are fine its just the Guides that have melted. Sorry about the bad suggestion. I know i roll all the way back. all the leaned. and all the slow . IEAw---DAY! creepy
